You should look into the LAYERSTATE-RESTORE function.EDIT: BBox beat me to it... This round.
You cannot modify the dialog via LISP... You can instead use the LayerState-* LispFunction Methods built-into the Visual LISP API however.
I am trying to create a script or lisp that will automatically open the layer states manager; select a layer state; activate it; then do a save as to X.dwg and overwrite it.
Could I do the above in a Script form? (To me script is easier to understand), but how would you go about that?
Thanks a bunch!!!!
... I want to then save the layer state and overwrite a file with the same layer state name.
