Author Topic: When Equal is not Equal...  (Read 4059 times)
MeasureUp
« on: May 31, 2013, 02:21:55 AM »
It is a bit strange to me:
(defun c:TEST ()
(defun DTR (deg)(* pi (/ deg 180.0)))
(defun TAN (deg)(/ (float (sin (DTR deg))) (float (cos (DTR deg)))))
(setq A 235.0)
(setq A1 (/ A (TAN 45.0)))
(setq B (getreal "B = "))
when I enter 235 for "B" then compare with "B" and "A1" like this:
(< B A1)
It returns "T".
What is wrong?
Your helps are much appreciated.
Marc'Antonio Alessi
  • Marco
Re: When Equal is not Equal...
« Reply #1 on: May 31, 2013, 04:49:10 AM »
Maybe this is the answer:
Command: (rtos (TAN 45.0) 2 16)
"0.9999999999999998"
fixo
« Reply #2 on: May 31, 2013, 08:09:44 AM »
You can also check this way
(if (< (abs (- B A1)) 0.0000001)) then equal. otherwise not
« Reply #3 on: May 31, 2013, 08:32:30 AM »
Consider the equal function with a tolerance to account for the rounding of doubles, e.g.:
  1. (equal a1 b 1e-8)
MeasureUp
« Reply #4 on: June 02, 2013, 07:47:25 PM »
Many thanks to Marc'Antonio Alessi, fixo and Lee for pointing out the difference between B and A1.
What I can see is that the"sin" and "cos" functions are not as good as what a handheld calculator does.
For example, (rtos (sin (DTR 30)) 2 20) returns "0.4999999999999999".
« Reply #5 on: June 02, 2013, 07:56:18 PM »
The handheld calculator works in exactly the same way to calculate the value, it simply rounds the result.
  1. _$ (rtos (sin (/ pi 6.0)) 2 16)
  2. "0.5000000000000000"
  3. _$ (rtos (sin (/ pi 6.0)) 2 17)
  4. "0.4999999999999999"
Since reals in AutoLISP are represented by double-precision floating point values (doubles), they can hold at most 16 decimal places of precision - this is likely more than that offered by your handheld calculator.
Please re-read: Floating Point Accuracy Problems, as linked above.
MeasureUp
« Reply #6 on: June 03, 2013, 01:30:53 AM »
Thanks Lee.
« Reply #7 on: June 03, 2013, 06:15:19 AM »
You're welcome.
