Author Topic: Change settings for all tabs selected in the new plotter in a single control  (Read 1497 times)
nini007
Hello forum,
I'm new to the forum and very new to lisp.
I found this lisp "Mim", attached to the CADxp site that is super convenient when we changed plotter.
But is it possible to add extra options such as:
- The size of the paper,
- The orientation of the drawing,
- The choice of ctb
- Enable plot styles (yes / no).
Thank you in advance
These threads may be of interest:
https://www.theswamp.org/index.php?topic=8855
https://www.theswamp.org/index.php?topic=1916
You would configure/import your plot configuration (page setup) with the appropriate settings, and then use the above to apply it to all layout tabs.
nini007
Hello,
Thank you for your response and links.
Indeed these links are interesting, unfortunately it does not fit my needs.
The links are focused on printing.
What I look for is a lisp that when we replace our plotter with a new one can change the configuration of presentations with a single click:
- The choice of ctb
In our default dwg we have a dozen presentations and it is tedious to go into every presentation to change the configuration.
Thank you for your help
Best regards
nini007
Hello,
I have a question to the forum.
Does anyone know the command to open directly the layout of a presentation.
To open the layout manager is: "_.pagesetup" and layout?
thank you in advance
Best regards
