Author Topic: How to speed this up?  (Read 3152 times)
Bulbasaur
« on: June 11, 2014, 03:14:02 AM »
Guys,
I just wrote the code as below and it went slow.
Can anyone tell me how to speed it up?
(mapcar '(lambda (p) (entmake (list (cons 0 "circle") (cons 10 p) (cons 40 10)))
             (setq e1 (entlast))
             (command "hatch" "s" e1 "" "p" "solid" "")
lst
Much appreciated!
« Last Edit: June 11, 2014, 04:24:46 AM by Bulbasaur »
Tharwat
  • Hypersensitive
Re: How to speed up hatching?
« Reply #1 on: June 11, 2014, 03:47:25 AM »
Hi ,
Set the system variable to zero then reset it back at the end of the program .
e.g ;
(setq cmd (getvar 'CMDECHO))
(setvar 'CMDECHO 0)
;; Your codes that related to hatch or any command call that used in a lisp routine ;;
(setvar 'CMDECHO cmd)
HasanCAD
« Reply #2 on: June 11, 2014, 03:54:20 AM »
Try out entmake
use this one as a gide
;; massoc (Jaysen Long)               ;;
;; Minor Modification by Jvillarreal ;;
;; Extracts info from list by key     ;;
(defun massoc (key alist / x nlist)
 (foreach x alist
     (eq key (car x))
     (setq nlist (cons x nlist))
 (reverse nlist)
);defun
(defun c:MergeHatch ( / hentinfo ss i ent ent# seedpt# entinfo entinfo2 ent# seedpt# seedpts MergedHatchList)
(while (/= (cdr (assoc 0 hentinfo)) "HATCH")
  (setq hentinfo (car (entsel "\nSelect Hatch Pattern to use:")))
  (If hentinfo (setq hentinfo (entget hentinfo)) (princ "\nMissed. Try again.")))
(while (not ss) (princ "\nSelect hatch entities to merge:")(setq ss (ssget '((0 . "HATCH")))))
(setq MergedHatchList
(list (cons 0 "HATCH")
      (cons 100 "AcDbEntity")
      (assoc 8 hentinfo)
      (cons 100 "AcDbHatch")
      (assoc 10 hentinfo)
      (assoc 210 hentinfo)
      (assoc 2 hentinfo)
      (assoc 70 hentinfo)
      (assoc 71 hentinfo)
      (cons 91 (sslength ss))
) i -1 seedpt# 0 ent# 0)
(repeat (sslength ss)
 (setq n -1
       entinfo (entget (ssname ss (setq i (1+ i))))
       entinfo2 (member (assoc 92 entinfo) entinfo)
       entinfo2 (reverse (cdr (member (assoc 75 entinfo2)(reverse entinfo2))))
       ent# (+ ent# (cdr (assoc 91 entinfo)))
       seedpt# (+ seedpt# (cdr (assoc 98 entinfo)))
       seedpts (append seedpts (cdr (member (assoc 98 entinfo) entinfo)))
       MergedHatchList (append MergedHatchList entinfo2)
(entdel (ssname ss i))
(setq MergedHatchList (subst (cons 91 ent#)(assoc 91 MergedHatchList) MergedHatchList)
      MergedHatchList
   (append
     (reverse (cdr (member (assoc 98 hentinfo)(reverse (member (assoc 75 hentinfo) hentinfo)))))
     (cons (cons 98 seedpt#) seedpts))))
(if (= (cdr (assoc 71 hentinfo)) 1)(setq MergedHatchList (append MergedHatchList '((-3 ("ACAD" (1010 0.0 0.0 0.0)))))))
(entmake MergedHatchList)
(setq ent (entlast))
 (mapcar
  '(lambda (x / entlist)
   (setq entlist (entget (cdr x)))
   (entmod (subst (cons 330 ent) (assoc 330 entlist) entlist))
  (massoc 330 MergedHatchList)
(defun c:MH () (c:MergeHatch))
Bulbasaur
« Reply #3 on: June 11, 2014, 03:59:12 AM »
Hi ,
e.g ;
(setvar 'CMDECHO 0)
Thanks for replying. I did set system variable to 0. It seems still slow tho. Maybe the problem is the code?
Bulbasaur
« Reply #4 on: June 11, 2014, 04:02:37 AM »
Try out entmake
 (foreach x alist
     (eq key (car x))
 (reverse nlist)
);defun
      (assoc 8 hentinfo)
      (assoc 10 hentinfo)
      (assoc 2 hentinfo)
      (assoc 70 hentinfo)
      (assoc 71 hentinfo)
 (setq n -1
      MergedHatchList
   (append
 (mapcar
Thank you buddy! I personally don't think entmake will make a big difference here. I will have a crack tho! Thanks again
irneb
Re: How to speed this up?
« Reply #5 on: June 11, 2014, 05:35:18 AM »
The entmake will probably be faster. But the reason you see hatch slowing everything down is due to it sarting off as a pick point hatch - effectively selecting EVERYTHING visible in the current virtual screen (which could be 1000's of objects). Old problem which adesk never fixed, but made worse when the ribbon was first introduced - if you turn off the ribbon then at least the hatch dialog pops up quicker.
Can't remember when this was introduced though - the HPDLGMODE allows the faster opening of the dialog, but you're still stuck with a slow command-line version. Thus far I know of no way to force a select boundary hatch as the default when the hatch command starts.
« Last Edit: June 11, 2014, 05:41:27 AM by irneb »
dgorsman
« Reply #6 on: June 11, 2014, 10:19:17 AM »
Solid hatch might not help either.  Boundary selection is pretty hard, I'm not certain what could be done to speed it up.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
LE3
« Reply #7 on: June 11, 2014, 11:30:15 AM »
just did a quick read here.... did you tried the old bhatch lisp?
don't have my old lisps code handy now, but maybe if you look into here:
http://www.theswamp.org/index.php?topic=9441.msg518783#msg518783
I almost 100% sure that bhatch can be called, the same as bpoly (lisp function).
i.e: ;;;(bpoly pt [ss] [vector]) ===> ;;;(bhatch pt [ss] [vector])
maybe....
hth.-
« Reply #8 on: June 11, 2014, 12:00:25 PM »
Yea, I have an old one.  8)
;;  Draw a Ying Yang Symbol in a circle
;;  CAB 07/20/2006
(defun c:yingyang (/ ent elst cen lay rad)
  (and
    (setq ent (car (entsel "\nSelect a circle.")))
    (setq elst (entget ent))
    (= "CIRCLE" (cdr (assoc 0 elst)))
    (setq cen (cdr (assoc 10 elst))
          lay (cdr (assoc 8 elst))
          rad (/ (cdr (assoc 40 elst)) 2)
    (entmake
      (list (cons 0 "ARC")
            (cons 8 lay)
            (cons 10 (polar cen (/ pi 2) rad))
            (cons 40 rad)
            (cons 50 (/ pi 2))
            (cons 51 (* pi 1.5))
    (entmake
            (cons 8 lay)
            (cons 10 (polar cen (* pi 1.5) rad))
            (cons 40 rad)
            (cons 50 (* pi 1.5))
            (cons 51 (/ pi 2))
    (command "-BHATCH" "_P" "ANSI31" "1" "45" (polar cen 1.57 rad) "")
« Reply #9 on: June 11, 2014, 12:09:01 PM »
Here is another removing the command call for the hatch:
(defun c:foo (/ doc e h obj p space)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq space (if (= (getvar 'cvport) 1)
(vla-get-paperspace doc)
(vla-get-modelspace doc)
     (setq e (entmakex (list (cons 0 "circle") (cons 10 p) (cons 40 10))))
     (setq h (vlax-invoke space 'addhatch achatchobject "SOLID" :vlax-true))
     (vlax-invoke h 'appendouterloop (list (vlax-ename->vla-object e)))
     (vla-evaluate h)
  (list (getpoint))
Bulbasaur
« Reply #10 on: June 11, 2014, 09:11:42 PM »
Many thanks guys. I tried 'bhatch' and it's faster...  I use donut in lieu of hatch in this case tho, which is much much faster ... Thanks again :-)
