Author Topic: Minimum distance between two vlax-curve objects  (Read 43467 times)
Joe Burke
Re: Minimum distance between two vlax-curve objects
« Reply #60 on: June 02, 2008, 08:30:47 AM »
Attached is an example file which demonstrates something I've run into while testing for parallel lines. A zero angle line after two rotations may report its angle as (* pi 2).
If the angle of the copied line is fed to the NormalAngle function contained in MinDist it will return 0.0.
« Last Edit: June 02, 2008, 08:42:42 AM by Joe Burke »
Joe Burke
« Reply #61 on: June 02, 2008, 10:52:26 AM »
(defun Paral3D (obj1 obj2 / a1 a2 acos)
  (setq a1   (vlax-curve-getFirstDeriv obj1 0)
a2   (vlax-curve-getFirstDeriv obj2 0)
acos (/ (apply '+ (mapcar '* a1 a2))
(* (sqrt (apply '+ (mapcar 'expt a1 '(2 2 2))))
   (sqrt (apply '+ (mapcar 'expt a2 '(2 2 2))))
  (zerop (atan (/ (sqrt (- 1. (* acos acos))) acos)))
Alan,
While this is interesting, do you think there's any reason to revise MinDist 1.0 to use it?
I think not assuming it is only testing for parallel lines.
« Reply #62 on: June 02, 2008, 11:40:15 AM »
I see no reason to change your code.  :-)
Joe Burke
« Reply #63 on: June 06, 2008, 10:48:06 AM »
I'm working on a version which allows selection of objects within blocks or xrefs at any nested depth.
Mostly done, but still a few kinks to work out.
Joe Burke
« Reply #64 on: June 08, 2008, 09:57:59 AM »
Here's the version mentioned above named MinDist 1.3 beta. Works with objects nested in blocks or xrefs.
See the header comments for a full explanation of what's going on.
I thiink this makes the routine much more useful. Hope you agree. :-)
Joe Burke
« Reply #65 on: June 10, 2008, 08:54:40 AM »
As is the routine will toss an error if a non-uniformly scaled block is involved. I'm working on error checking for that condition.
Joe Burke
« Reply #66 on: June 11, 2008, 08:13:43 AM »
Version 1.4 beta. Added error checking for non-uniformly scaled blocks.
« Last Edit: June 24, 2008, 07:08:43 AM by Joe Burke »
Joe Burke
« Reply #67 on: June 24, 2008, 07:09:47 AM »
Minor bug fix version named MinDist 1.4a attached. See the header comments for version history.
« Reply #68 on: June 24, 2008, 08:12:16 AM »
Thanks Joe.
Joe Burke
« Reply #69 on: June 24, 2008, 09:14:10 AM »
Alan,
Thanks for your help with the code.
« Reply #70 on: June 24, 2008, 09:49:51 AM »
Nice job Joe  :-)
Joe Burke
« Reply #71 on: June 25, 2008, 08:10:02 AM »
Thanks, ronjonp.  :-)
mikeg
« Reply #72 on: July 02, 2008, 02:40:34 PM »
Wow this code works great! Mind i use it guys that worked on it?
Joe Burke
« Reply #73 on: July 04, 2008, 06:25:20 AM »
Glad to hear you like it. Use as you wish.
Updated version attached. Added support for object types point, ray and xline. Also works with objects nested in dimensions.
chlh_jd
« Reply #74 on: January 02, 2012, 09:30:22 AM »
Happy New Year to All .
Hi Joe , just read your works , Good job .
However , I guess it can be get by higher Accuracy , I post my poor codes , I hope you don't mind . :-)
(defun c:test
      (/ en1 e en2 fuzz l1 l2 lim l0 d0 p0
       p)
  ;;by GSLS(SS) 2012.1.2
  (defun getlength (e)
    (vlax-curve-getDistAtPoint
      e
      (vlax-curve-getendpoint e)
  (defun f0 (a b / mid rslt)
    (repeat (/ (length a) b)
      (setq mid nil)
      (repeat b
(setq mid (cons (car a) mid)
      a   (cdr a)
      (setq rslt (cons (reverse mid) rslt))
    (if a
      (reverse (cons a rslt))
      (reverse rslt)
  (defun f1 (e p)
    (distance p (vlax-curve-getClosestPointTo e p))
  (defun f2 (e1 e2 p lim / l0 d0 p0 l)
    (setq l0 (vlax-curve-getDistAtPoint e1 p)
  d0 (f1 e2 p)
  p0 p
  l  l0
    (repeat 10
      (setq l (- l lim))
      (if (and (>= l 0) (setq p (vlax-curve-getpointatdist e1 l)))
(if (and (setq d (f1 e2 p))
(< d d0)
  (setq d0 d
p0 p
    (setq l l0)
    (repeat 10
      (setq l (+ l lim))
(< d d0)
  (setq d0 d
p0 p
    p0
  (defun f3 (e1 e2 lim / mid)
    (if (not
  (minusp
    (vlax-safearray-get-u-bound
      (vlax-variant-value
(setq mid (vla-IntersectWith
    (vlax-ename->vla-object e1)
    (vlax-ename->vla-object e2)
    lim
      1
      (list-comp (vlax-safearray->list (vlax-variant-value mid))
3
  (setq en1 (car (ss-Nentsel "\nSelect First Curve :"))
en2 (car (ss-Nentsel "\nSelect Second Curve :"))
  (setq fuzz (getreal "\nType in Accuracy <1e-6> :"))
  (or fuzz (setq fuzz 1e-6))
  (if (and en1 en2)
    (if (f3 en1 en2 0)
      (princ "\nThe 2 Curves is intersectwithed !")
(setq l1 (getlength en1)
      l2 (getlength en2)
(if (< l2 l1)
  (setq e   en1
en1 en2
en2 e
l1  l2
(setq lim (/ l1 (1+ (fix (/ l1 200.))))
      l0  0.
      d0  1e308
(repeat (fix (/ l1 lim))
  (setq p (vlax-curve-getpointatdist en1 l0))
  (setq d (f1 en2 p))
  (if (< d d0)
    (setq d0 d
  p0 p
  (setq l0 (+ l0 lim))
(setq is_go T)
(while (and (> lim fuzz) is_go)
  (setq p (f2 en1 en2 p0 (setq lim (/ lim 10.))))
  (if (equal p p0 fuzz)
    (setq is_go nil
  p0 p
    (setq p0 p)
(setq p (vlax-curve-getClosestPointTo en2 p0))
(entmakex (list (cons 0 "LINE")
(cons 8 "Defpoints")
(cons 10 p0)
(cons 11 p)
(cons 62 1)
(defun ss-Nentsel (msg / en en1 pt mat ins mat ent )
  (setq en (Nentsel msg))
  (if (= (length en) 4)
      (setq en1   (car en)
    pt    (cadr en)
    mat   (caddr en)
    ins   (last mat)
    mat   (butlast mat)
    mat  (ss-getrcsmatrix mat ins)
      (setq ent (entget en1 (list "*")))
      (setq ent (vl-remove (assoc -1 ent) ent))
      (setq en1 (entmakex ent))
      (if en1
  (setq obj (en2obj en1))
  (vla-TransformBy obj (vlax-tmatrix mat))
  (setq en1 (obj2en obj))
      (list en1 pt T)
    (append en (list nil))
;;; BY GSLS(SS)
;;; 2010-09-29
(defun ss-getrcsmatrix (lst org)
  (append
    (mapcar (function (lambda (x y)
       (append x (list y))
    lst
    org
    (list (list 0. 0. 0. 1.))
