Author Topic: Authorization code  (Read 1292 times)
Gliderider
Authorization code
« on: August 02, 2006, 07:19:57 AM »
Is there a way to access the authorization code for an installation of acad? We're replacing computers around here and the fellow who did the prior installations is no longer here, and I can't seem to find where he put the authorization code (if he recorded it).
nivuahc
Re: Authorization code
« Reply #1 on: August 02, 2006, 07:21:56 AM »
Call your reseller. Or Autodesk. They can get the info for you.
nivuahc
« Reply #2 on: August 02, 2006, 07:25:49 AM »
Also, take a look in the installation folder for an HTML file called RegInfo*.html
For example, the one I have for Map 5 is
C:\Program Files\Autodesk Map 5\RegInfoMAP.html
The authorization code is in there, just open it with Firefox or Internet Exploder
Gliderider
« Reply #3 on: August 02, 2006, 09:22:12 AM »
Thanks, I'll guess I'll have to get a hold of Autodesk.
