Author Topic: IAcadBlockReference2 and AcadBlockReference, how to use both  (Read 3116 times)
jjs
I have some users on version 2004 of vanilla autocad. I just installed a 2006 trial version of ABS, but I use 2004 for my production stuff. It must have changed my TLB file and now I cannot use AcadBlockReference on my machine. But I need the code to run on both machines. Machine that does not have 2006 installed and one that has both 2004 and 2006 installed. Any suggestions?
JJS
Bob Wahr
Re: IAcadBlockReference2 and AcadBlockReference, how to use both
« Reply #1 on: June 29, 2006, 01:14:26 PM »
you could use acadver to check which version is running
All I can think is to check the registry to see if 2006 is installed and code accordingly. sortof
if not boo2k6Loaded then
  Dim objBlkRef as AcadBlockReference
Else
  Dim objBlkRef as IAcadBlockReference2
Bob Wahr
« Reply #2 on: June 29, 2006, 01:15:51 PM »
Another thought it try reinstalling 2004 and see if it fixes itself.
Bryco
« Reply #3 on: June 29, 2006, 02:13:38 PM »
I had the same problem with a trail version.
Deleted the trial version then reloaded 2004 and was fixed.
Like you said, the 2004 reads a 2006 tlb.
I dont have this problem with 2004 and 2006 registered versions on the same machine
jjs
« Reply #4 on: July 21, 2006, 10:11:28 AM »
we just ordered 2007 abs, so i can uninstall the 2006 version and get my 2004 fixed back up. Hopefully 2007 should have a completely separate tlb and i can have separate versions.
Bryco
« Reply #5 on: July 21, 2006, 08:02:41 PM »
JJS, I played a little with  IAcadBlockReference2 and the block versions, it seems like you never have to dim something as a 2 to get the 2 properties. That is, dim it as AcadBlockReference and you still have the properties but not the intellisense.
